Thread: Mt7 brake lever issue
    Bit north of Sydney
    673
    Default Mt7 brake lever issue
    My lever keeps dropping down away from the bars, the other lever springs back. So not sure what is going on here. I've had a look at it and can't even figure out how to take the lever off. The magura docs I've found don't help. Any ideas?
    Also, any idea what olive I need to shorten the lines, my asymmetric one from hs33 is different.
    Sent from my Nexus 5X using Tapatalk
    Bit north of Sydney
    673
    the guys at tartybikes helped me with this one. the problem is the BAT adjuster, for some reason with some lever blades it causes this, just need to pull the lever and rotate it and sorts it out.. some positions of the BAT the level just doesnt like.
    they also said the thin covers on the top/bottom can be gently lifted with a knife to reveal the pin..
    all very easy when you know how! haha
    Senior Member Tubbsy's Avatar
    Apr 2009
    348
    Pretty sure I have loads of olives for Magura in my spares assuming these are the same as on the Marta.
    Nov 2005
    Pennant Hills; Sydney
    164
    the guys at euro cycles helped me out when i had a problem with my maguras <https://eurocycles.com.au/brands/magura.html> And they're local.
