Thread: Fox Talas 32 R rebound adjuster knob fell out.
    Nov 2009
    6
    Default Fox Talas 32 R rebound adjuster knob fell out.
    Hi Guys,
    I just bought a pair of Fox Talas 32 R rebound forks on Ebay. They're the ones that you can change the travel from 100-120-140 mm. When I was hammering in the Star Nut the red rebound knob on the top of the right fork fell out. It has a small hex bolt that is still bolted into about 5 mm of aluminium and I can't tell whether it's snapped off or if that's how it's supposed to be.
    I am able "click" the rebound knob back in as it has a piece of wire in the top of the fork that holds it in place and it "clicks" when I turn it however it keeps turning and doesn't stop at either a maximum or minimum setting. Also when I turn it it doesn't seem to adjust the rebound.
    I've tried googling for a diagram without success. Does anyone know what the rebound knob should be screwing in to and therefore whether it has snapped or if it hasn't snapped how I can get the rebound adjustments to take effect.
    thanks,
    John
    1,128
    Sounds like the rebound shaft is snapped, you won't be able to get the rebound to adjust unless you get a new shaft
    Nov 2009
    6
    cheers, do you think that would be expensive including installation? I wouldn't be confident doing it myself.
    Jul 2009
    1,042
    I'm not sure where you're located but drop Simon @ MTB Suspension Centre a line, he helped me out with some missing parts I had on a pair of Fox forks, website https://www.mtbsuspension.com.au/
