Page 1 of 7 123 ... LastLast
Results 1 to 10 of 64
Thread: Replacing Gear Shifter
    Aug 2016
    48
    Default Replacing Gear Shifter
    Hi all,
    The young fella come a cropper on his MTB, and looks like the rear gear shifter on the right may have got a little nudge. It would only ocassionally shift down into lower gear (higher rear cog), but shifting up gears was fine. Got to the stage where you could push the whole gear lever all the way to the front of the bike without engaging another gear, ie loose. I took the bottom off and gave it a clean and improved for a few minutes the gears would change up and down fine. I have freed the pawl up etc. I have compared to the other gear shifter and I think the problem is the nut at the bottom holding the gear levers in etc is not as tightened as the other, thus the gear lever can move around a little. I have tightened it the best I can but there is not much to grab on the nut.
    I was hoping to come from the top and see also if anything was loose etc. Anyone know how to actually get the top cover off which has the gear numbering on it? It is made hard by the bracket as I cannot get the bracket off as it is one of those tight one that jut clamps with a bolt.
    Would it be just easier to buy a new altus shifter and install that? How do you get the old one off with those tight brackets? Do you have to remove the grips and slide it off? The gear shifter is a Shimano Altus SL-M370.
    Thanks
    Senior Member wkkie's Avatar
    Clifton Springs, Vic.
    1,814
    Sounds like a good chance to upgrade from the Altus.
    They are pretty low end and the time you've spent on it already probably far outweighs the cost of the actual shifter!
    Even something second hand (deore / slx) would be a good option.
    18,176
    Shimano zee time.
    Remove grip and slide the shifter off. Sounds like the thread may have stripped and it won't hold on again.
    26,182
    Shimano zee time.
    Good advice...except Altus is 9sp and zee is 10...
    Senior Member Ezkaton's Avatar
    Apr 2013
    Melbourne, VIC
    2,615
    Would the shift range be limited by the derailleur's high or low screw to stop the shifter from being able to shift that one extra click?
    Or are they just flat-out incompatible?
    If I rode a fixie and nobody saw it, was it still cool?
    26,182
    Quote Originally Posted by Ezkaton View Post
    I'm not 100% sure they aren't, but there will be piles of old 9sp Shimano shifters out there, so I'd just stick with that. Pretty sure I've given away all mine, but can check tonight.
    Aug 2016
    48
    Quote Originally Posted by wkkie View Post
    Yep, agreed, already spend a couple hours on it. If I upgraded the shifter, do I have to upgrade the shifter for the front derailleur also? The rear derailleur is deore.
    Aug 2016
    48
    Shimano zee time.
    Yeh I think the shifter is "no recessed" into the other shifter if that makes any sense? They are not flat against each other and a little loose (can wobble it a little side to side and up and down), but if I slide the shifter whilst holding it up, it shifts OK. I works OK when I turn it upside and look at the pawl and internals I guess because the shifter is not hanging down.
    Aug 2016
    48
    Thanks mate. I see you are from Buninyong, must be cold there today!
    1,814
    Quote Originally Posted by daazzaa View Post
    If the front shifter is still working then you can leave it. Some here though might say that removing the front shifter would be the upgrade!
    But just changing the rear shifter is all you need.
