Thread: Drop bar dropper remote hack
    388
    Default Drop bar dropper remote hack
    am looking for clamp ideas to fit a dropper remote to my cross bars diameter 23.8mm, as opposed to normal mtb grip diameter of 22.2mm, its for a cable, not a hydraulic. also the shifters are SS, so can't use the 2x/3x of the front derailleur shifting. thanks
    Cotic BFe[gone to oldest], old Yeti as-r[retired], focus CX,Lapierre xr529
    Member linkl8r's Avatar
    Apr 2015
    80
    KS southpaw should work on that diameter mate. It's an open two part clamp.
    Sent from my Moto G Play using Tapatalk
    Jan 2005
    Brisvegas
    1,122
    Lev lever (the standard one) would probably work as well, and look a fair bit neater on a drop bar than say a southpaw. You are welcome to mine if you want it...
    You say the "shifters are SS"? Confused by this, but guessing you mean that they are brake levers only not brifiters. Installing one (or both) brifters would be by far the neatest
    Focus Spine Factory C- X01- Pikes
    Soma 650B-Side - X9 1x10 -Revelation RL
    Giant Defy Advanced Pro 0- Ultegra 6870 + R785's
    Aug 2016
    34
    Quote Originally Posted by 99_FGT View Post
    If this is the case you may be able to hack a brifter (removing the indexing ability) to activate the dropper. You would have to check how much pull you need on the cable compared to the pull available on the brifter.
    388
    yep just brake levers only, the trp hydraulic ones
    Senior Member Nerf Herder's Avatar
    8,816
    Check the Mountain Biking Australia website ... Mr Hardwick had a CX with KS post and he outlines a mod for the remote ... Or email me as I'm sure KS sent me an article outlining a mod for a dropper.
    note, better to check MBA ... I'll be slow on email Soz, mayhem at present
    Senior Member swaz's Avatar
    Jun 2013
    Nowhereville
    1,233
    Pretty sure I have a carbon fibre KS lev dropper remote
    Successful trades: F1234K
    388
    cheers Nerf i searched but couldn't find it
