Results 1 to 10 of 33
Thread: OneUp Components EDC Every Day Carry tool
    10,163
    Default OneUp Components EDC Every Day Carry tool
    Welcome to the next exciting review on products provided to us by our friends at Mountain Bikes Direct. We've teamed up with one of Australia's best online mountain bike stores to bring you in depth reviews on the latest and most intriguing parts and accessories you can purchase for your bike.
    The values shared by the staff at Rotorburn and Mountain Bikes Direct are the same; we have a huge passion for mountain biking! It's our pleasure to be in a great position to test, review and share our in depth details on some great products available from Mountain Bikes Direct.
    Item: OneUp Components EDC Every Day Carry tool
    Purchased From: Mountain Bikes Direct (Click here for the product page)
    Purchase Price (approx): $79.95
    Usage: Any discipline of mountain biking or road riding
    Pros Ė Super compact, doesnít require additional methods to store tools, very light.
    Cons Ė Itís a compact multi tool that doesnít have everything you may be used to with bulkier and heavier multi tools.
    Product outline: The idea of the OneUp Components EDC Every Day Carry tool is to store the tools youíll need in vacant spaces on your bike instead of suspending the weight of items you carry in your backpack or pocket. This tool simply slides into your fork steerer tube after a small amount of time is applied to tap a thread into your steerer tube. The compact design means itís one less item you may forget to pack in the event that youíll need it when youíre an hour from the car. Itís quite surprising just how versatile this small tool is and just how commonly used the tools affixed are. It includes the most used hex wrench sizes (2, 2.5, 3, 4, 5, 6, and 8mm), a T25 torx, a plastic tyre lever, flat head screwdriver, four spoke keys (0,1,2,3), a presta valve core tool, a chain breaker tool and comes with a small sealed capsule to store small parts like a quick link, a CO2 cartridge and items of that size. Thereís also a tool to tighten the top cap if need be.
    Bike used: Norco Charger hardtail
    Fitting: Fitting is simple but does require you to pay close attention to the small details outlined in the video OneUp Components offer on the product page. You will need to also grab yourself the kit required to tap a thread into your steerer tube and the top cap to fasten the EDC in place. Both items can be found on this page.
    Once youíve picked up the extra kit needed to fit, youíre all set. Watch the video first then jump on in and get the thread tapped. Honestly, the video tells you everything you need to know to fit again, pay attention to the small details they provide as they are crucial to you getting it right. Even if youíve never played around with tapping threads or removing star nuts, it really is so simple and very much worth getting right. Trust me, itís easy!
    Once the thread is tapped, I recommend cleaning the thread with a toothbrush and ensuring your steerer tube is free from any shavings left over. The edge can be quite sharp so donít slice your finger open. I did apply a small amount of grease to the first part of the thread on the top cap to allow the thread to ease into the new thread. The EDC comes with a small tool that tightens the top cap but you can also use a cassette lockring tool to get it nice and firm. Double check your headset is in place with no rocking as well. The last step is to put the bottom cap into the crown of your forks to keep everything intact. You may need to tap that guy in with a rubber mallet to ensure it sits firmly in the crown. After that is in place, grab your EDC and lock it in. All done!
    Please keep in mind that the method used to affix the top cap to the steerer removes the traditional top cap and star nut setup. It is important to get the new thread tapped perfectly the first time so pay attention to the video. Is this method of tapping a thread into you steerer tube more reliable than a star nut and top cap set up? You bet! I think itís probably the best way to keep the whole system in place. Why? Thereís more thread for your top cap to bite into, thereís no chance of a dodgy star nut pulling up as you tighten the top cap bolt and you can get a precise height for your spacers.
    On the trail: First up; you wonít notice the weight of it. Itís less than 250 grams and is out of sight. Itís tucked in very tightly with quality O rings that mean it wonít rattle, it wonít come bouncing out of your steerer and itíll stay clean. You can get the EDC out of the steerer by pulling on the tab that locks it into place and there you go, itís in your hands without taking your pack off or fumbling in your pocket. The whole point of the EDC is to simplify the process of carrying a multi tool and keeps it compact. Itís that simple, it takes a no fuss approach to utilising vacant space on your bike and itís within easy reach. For those that have multiple bikes, you can grab an extra top cap set up and use the same thread tap to make all your bikes compatible. You can only ride one bike at once so just swap the EDC between bikes and youíve got a common multi tool on each.
    Summary: The build quality and finish on the OneUp EDC is great. Itís made from great material and machined very nicely. Each tool is a precise fit for itís intended use and it doesnít feel like itís about to snap under load. The small sealed tube for extra part storage is surprisingly very useful for storing those small bits that you lose in the pockets of your pack, itís very versatile. There will always be other tools you may need away from your workshop but the functions included in the EDC can most definitely get you out of a bad situation and keep you riding. Donít be put off by the need to grab some extra items required to fit the EDC, itís that good that itís totally worth it. The fitting is easy and the tools offered to fit the EDC are of a quality that means the best result is easy.
    Thanks to our friends at Mountain Bikes Direct for the exclusive use of their products for this and many more reviews to come.
    Senior Member slowmick's Avatar
    Jul 2012
    1,534
    nice review. bummer that the installation tool is $40 extra and you need 5mm of steerer above your stem. Looks like a good idea for shops that do custom builds to offer as an added bonus feature to their builds.
    Just re-read - you need to spend $34 on the top cap kit too. That makes it a $153.85 trail tool. wow.
    Blue Mountains
    337
    What's the quality of the tap tool like?
    Just wondering how many threads it would happily tap before it goes in the bin.
    Feb 2005
    212
    Default Good review - well done
    Thanks for the good read.
    But I don't think I'll be replacing my Alien with this anytime soon
    As slowmick says, maybe for a new build for a new rider or for the people who don't like packs
    We have a fellow who rides with us that can't stand backpacks, so he has stuff like spare tubes, tools, CO2 cartridges and two water bottles hanging from every bit of his bike - looks pretty kooky!
    Me? I don't mind my Camelbak - once you've gotten used to them, they aren't really that intrusive
    10,163
    Quote Originally Posted by notime View Post
    It's excellent. Coming from a fabrication background I can say that it's a quality tap. I don't think you'd ever wear it out or have it distort the pattern. It's pretty heavy duty.
    222
    When they posted this on pinkbike I suggested they make a top cap instead of tapping the stem... I'm tempted to buy one just to make it and sell them.
    No mods to your bike and you can transfer it between bikes.
    3,384
    The whole tapping thing plus the fact that you:
    1. Have only one CO2 canister, and;
    2. No CO2 head
    means that I feel this combo is a better idea:
    That way you get all the tool goodness plus a backup should you misfire your CO2 canister.
    And tool + pump is just about the same price as tool + top cap + tap kit.
    Good review though
    Oct 2010
    133
    I would have thought with it's weight, gravity, and a friction fit that the o-rings would hold it in there tight enough without the need to tap?
    3,384
    The tapped threads don't hold the tool in, they - along with the new top cap - allow you to preload the headset in the absence of the starnut.
    You could I suppose use a Hope Headset Doctor thing to preload the headset, tighten the stem & replace the Hope thing with the EDC?
    Oct 2009
    Wollongong
    439
    I like the idea, but a custom frame bag would be the better option on that bike and for that price if you could loose the saddle bag.
