Results 1 to 3 of 3
Thread: Norco Range Shock replacement.
    Junior Member Jonb1760's Avatar
    Jul 2016
    8
    Default Norco Range Shock replacement.
    Hey guys, am looking at replacing the x fusion shock on my 2015 range. I have the option of a Monarch plus R shock. Would this be a straight swap or if not what size spacer kits upper and lower would i need?
    TIA. O
    Jul 2016
    8
    Next question does anyone know the size of the upper and lower shock mounting bolts on a norco range? And has the frame dimensions changed over time?
    Jul 2016
    8
    Hey guys I bit the bullet. Got a good deal on a RockShox Monarch Plus so in case anyone is interested I swapped the x-fusion for the monarch. It was a piece of p... .
    The x-fusion had press bushings top and bottom that came straight out and went straight into the Monarch. No extra hardware required. Now if it wasn't blowing a gale and blizzard in the Snowy's I'd go test it.
