Thread: BB install on 73mm frame
    Central Coast
    604
    Default BB install on 73mm frame
    Just building up my pivot point frame, got a set of Zee cranks to install that come with BB52 deore. My understanding is the BB doesnt need any spacers as the shell is 73mm, however, when I install the crank there is bugger all space for the left arm to tighten up. I have it installed as such and I cant get any lateral play from the arms so it seems ok, but wanted any ideas from the brains trust if I should stick a spacer on one or other side of the BB??
    Also, any other suggestions for better quality BB, this BB52 seems pretty cheap.. the threads are like paper, Id be worried removing the BB would ruin the threads for good.
    11,486
    73mm bsa bb generally requires 1 spacer, on the drive side (I think from memory, but I chop and change depending on bike). 68mm shell requires 2 spacers.
    3,621
    Yes, one spacer on the drive side. The crank/BB assembly is designed to allow for the fitting of a bottom bracket mounted chain device, which typically has a 2.5mm thick mounting plate. If not using such a device, use a spacer in its place.
    For interest's sake, a 68mm shell would require a spacer on each side to correct for the shell width difference, plus the additional spacer or BB-mounted chain device on the drive side.
    Central Coast
    604
    awesome thanks guys, makes sense now! will put a spacer in there before I ride it!
    cheers!
