Results 1 to 9 of 9
Thread: Pike service question
    Sep 2014
    558
    Default Pike service question
    Hey Guys,
    Just doing an oil change on my Pikes and had a Q about the pressure on the negative side of the air piston when reinstalling it. I'm used to working with Fox forks which don't have a seal on the lower end air side so there is little or no opposing pressure. Do you stick a cable tie or similar down the between the piston seal to release pressure or just stick it back in as is?
    C
    And even worse is the one stupid cunt that doesn't even notice the issues!
    Quote Originally Posted by Ultra Lord View Post
    asked me to do it at stromlo carpark the fuckin twat.
    1,084
    Should be able to just stick it back in. If not, unscrew the valve core on the positive side
    Sep 2014
    558
    Quote Originally Posted by c3024446 View Post
    i took the piston out from the top. No trouble getting it in, but curious about the pressure on the negative side.
    Actually now that i think about it more I'm guessing the negative pressure negates the need for thetop out springs as are used in Fox forks?
    1,084
    The spring in a fox air fork is the negative spring. Rockshox use air as the negative spring. Couldn't adjust the negative spring in a fox fork like you could with the Rockshox, hence why Fox have finally started making forks with a negative air spring recently......
    Sep 2014
    558
    Thanks for that! Mine is a solo air so there's no adjustment on the negative side..
    3,621
    There's usually a little nick machined into the inner wall of the air sleeve, which is a pressure-equalising bypass port. Basically just shove the air piston in, reassemble the fork, and after you pump the positive chamber up to pressure, jump on the fork a couple of times. as the piston slides past the bypass port, a bit of air will transfer into the negative chamber.
    1,685
    Quote Originally Posted by The Duckmeister View Post
    ... jump on the fork a couple of times...
    When you pump the fork up, it should go to full extension. At full extension the pos and neg chambers will equalize. If you run really low pos pressures you may need to pull on the fork so it extends fully the first time you pump it back up, otherwise, pump it up more and then once its reached full extension, let pressure out until you're at your desired sag setting.
    Wanted: broken 10 speed XTR rear derailleur
    Sep 2014
    558
    Ok, thanks for that!
    Sep 2014
    558
    Quote Originally Posted by SummitFever View Post
    Many thanks!
