Results 1 to 10 of 10
Thread: Collapsed Hub Bearing Removal
    Senior Member deadlegs's Avatar
    Dec 2015
    127
    Question Collapsed Hub Bearing Removal
    Hey Guys,
    I had a bearing collapse on my old 26er EASTON wheel set (DRIVE SIDE).
    I have the replacement bearings to go in.
    My question is does anyone have any DIY tricks on getting the collapsed bearing out without using a bearing puller.
    cheers,
    cam
    camoshop.V2
    3141
    3,788
    Cant get to it from the other side with a long flat head screwdriver and a hammer?
    Senior Member Ultra Lord's Avatar
    Grays Point
    952
    Heat gun? Small die grinder with a cutting disk attached (its a bitch but I have done it.)
    Failing that find a mate with a tig welder and add material to the inner of the ace and try and tap it out using a screw driver. Just dont weld the race onto the hub
    I rode Newtown, before it was cool.
    Dec 2015
    127
    Quote Originally Posted by Shredden View Post
    yeah i tried that but its on the free body side so its recessed and you cant get the the back edge of it.
    Quote Originally Posted by Ultra Lord View Post
    might try the cutting disk option.
    cheers!!
    camoshop.V2
    3,621
    That's generally the first option, but when the bearing has shat itself & only the outer shell is left there's not much to hit against.
    Senior Member Oddjob's Avatar
    1,673
    Safest option is to use blind bearing puller with correct size collete. Ring around local lbs or motorbike shops.
    Dremel with diamond stone would make short work of it but need to be careful not to cut through into the hub. Should be able to deform race with jewelers screwdriver when you are almost through.
    Quote Originally Posted by alexb618 View Post
    people with singlespeeds and street fixies seem to spend a lot of time cleaning and taking pics of their bikes for the internet rather than riding them :confused:
    Senior Member hathill's Avatar
    Nov 2009
    Under a rock
    142
    Default Use the percussive technique below.
    Is the bearing flush with the outside flange or recessed deeper into it?
    If the latter, maybe try a couple of sharp raps onto a soft-ish block of wood to see if it will move and give you access to the back of the shell you can then tap out with an appropriate tool/s.
    Edit: - Stupid me just realised this may be a bit difficult as it's still attached to the wheel. May work if it was the hub only.
    “Corollas are great cars, but you can’t pick up chicks in one”
    11,486
    Going to come across as flippant, but bin it and lace in a hope, any hope. They're practically bullet proof, but can be completely stripped by hand, and reassembled with nothing more specific than an appropriately sized socket, but 9 times out of 10, with a lump of wood, on the tray of a Ute, in a city lane way.
    Only being partially facetious.
    11,486
    Don't heat, you will more than likely warp the alloy seat before you get enough temperature into hardened steel race. Similar goes for cutting, but you have the double jeopardy of over heating the seat, and/or scoring it with a high speed rotary tool.
    Grays Point
    952
    You dont want to get heat into the race, and the aluminium shell will expand long before the steel race and will require much less heat.
    If it was an inner race stuck on an aluminium shaft yeah, heat wont help.
    Your other post is bang on though.
