Results 1 to 10 of 18
Thread: Forked decisions....
    Senior Member born-again-biker's Avatar
    Dec 2014
    The little island at the bottom
    297
    Default Forked decisions....
    So I've been sniffing around for a fork upgrade for a while.
    I was only looking for 15x100's because my bike is pre-boost...and the "old" standard is starting to get a little cheaper.
    ....but...it just occurred to me that I could widen the search to 15x110 forks & add an adapter kit for my non-boost wheel & therefore "future proof" the fork for the inevitable next bike/wheel-set...down the track...
    Arguably the 15x100 forks that cost plenty $$$ today, will soon enough be worthless & out of favour in a couple of years?
    My only concern is my front hub already has 20mm-to-15mm spacers fitted...so assuming I could even find a kit that was appropriate, I would end-up with a frankenstein set up that might be prone to excessive flex, excessive wear or failure...or all three....??
    So thoughts?
    I'd be interested if anyone has had any issues running boost forks+adapters+100mm hubs over longer term use? Any weaknesses?
    I'm nudging 100kg's fully kitted & ride "aggressive trail" style (whatever that means this month)
    I specialise in riding beyond my limits, artistic blood-soaked OTB's and breaking components.
    4,042
    What hubs have you got?
    Also remember that it's not just adapters that you need, you also need to redish the wheel.
    Wolftoooth already do Hope and DT Swiss adaptors (boostinator) that do exactly what your asking.
    Senior Member yuley95's Avatar
    Jan 2011
    550
    Why do you have to re dish a front wheel with adaptors? I was thinking you just add adaptors and you're done.
    18,415
    Quote Originally Posted by yuley95 View Post
    How does the brake line up in your system?
    I know these feels...big buy into 26 just before it really died...then I just kept digging. Still digging...I sure of a comeback.
    3,621
    Because with a standard-width hub in a wider-spaced fork, the brake rotor is almost certainly going to be further inboard than the small lateral adjustment of the brake caliper can handle. So you'd need to put all your packing-out on the non-disc side so the rotor fits in the caliper, then pull the wheel back on centre.
    Dec 2014
    297
    Hmm...I forgot about brake rotor location....
    Glad I asked.
    Jan 2005
    Brisvegas
    1,145
    There are options like the problem solvers one which is 2 5mm loose spacers and a 5mm disc spacer.
    Or reinstall your 20mm end caps and get one of these, plus the 5mm disc spacer
    http://www.ebay.com.au/itm/MTB-Tools...-/252082256474
    Assuming that these will clear the dropout ok of course
    Focus Spine Factory C- X01- Pikes
    Soma 650B-Side - X9 1x10 -Revelation RL
    Giant Defy Advanced Pro 0- Ultegra 6870 + R785's
    Senior Member Nambra's Avatar
    505
    Assuming you can work your existing wheel into a boost fork, this might be of interest to you - Pike DPA for a bit over $600:
    https://www.bike-components.de/en/Ro...ackung-p58167/
    Oct 2010
    133
    or just save the hassle and get these for $600 + postage
    http://www.bike-components.de/en/Roc...ackung-p58167/
    Nov 2015
    Dandenongs, Victoria
    46
    Shit that's cheap there rockshox are stupid cheap a lyrik in 170mm 27.5 shipped all up for under 1k..... Was in the same boat as you not so long ago as boost forks are sort of the norm now I honestly don't feel the benefit but that perhaps I have a better/stiffer wheelset.
    Sent from my Nexus 6 using Tapatalk
