Results 1 to 10 of 25
Thread: 2004 Kona Stinky
    3,153
    Default 2004 Kona Stinky
    I bought Plankosaurus' 2004 Kona stinky for a bargain price. She's to become bike number 4 in the fleet. Bikes 4,5 and 6 are all on the go.
    She needs a full rebuild, has spent some time in the rain. So far I've fully stripped her down.
    Stuck trying to get the main pivot bearings out, I'm assuming the bearing seats are semi blind so I've tried pulling with no luck, going to have to cut them out it would appear.
    Plans are a little sketchy still. Paint has to go. Thinking raw
    Unsure what to do about the forks, but my stash of 32mm zocci is pretty good, I'm thinking a fox FIT cartridge might be the go with some 20mm DJ3 lowers, rear coil shock is a vanilla r with propedal and seems to be quite good as far as platform goes, might try it once she's back together before hunting for an air shock
    Wheels will be mavic 823 on pro2
    Brakes will be Guides.
    ATF/Acetone left to soak into the bearings in an attempt at removing them, sadly no joy.
    Senior Member andrew9's Avatar
    Dec 2015
    189
    I really like the old paintwork, I'd try and keep it, maybe do some careful touch ups of the black to freshen it up.
    My old stinky had Fox40's, dropped to 175mm travel. I really liked it as a Mini-DH bike, but a single crown makes more sense.
    It also had the Vanilla R, and it worked pretty damn well really
    Senior Member Plankosaurus's Avatar
    Feb 2005
    Sunny Sunny Selby
    1,154
    It's funny you say that, because he happens to have a set of 36 vanillas as well :-P
    Awesome that the old beast is getting some love, it's a lot more effort than i thought the bargain basement boat anchor would receive! I'm not sure it's a pretty enough bike to work raw personally, but then I saw it as nothing more than a stepping stone for someone wanting to take a crack at riding downwards so maybe my opinion is invalid.
    Sent from my Xperia Z3C using Tapatalk
    Nothing goes over my head, my reflexes are too fast
    Aug 2008
    421
    Cool, i also have an old Stinky at home with a Vanilla and Marzocchi Junior T up front, no real plans for it yet but ya never know.
    19,215
    Get your huck pants on!!!
    Senior Member Mr Crudley's Avatar
    Upper Suburbia Heights
    1,376
    Huck me dead, go the gnar........ Beeeetcheeennnnn......
    Sent from my F5121 using Tapatalk
    19,215
    He'll be drowning in it!!!
    2,871
    Try freeze and release spray on the stuck bearings.
    3,153
    Used a whole can trying, bearings are a little too deep and the housing a little too corroded. And by the time I freeze a bearing and get the blind puller in and seated, there has been enough heat transfer to deny success. I do love a can of freeze and release.
    A gentle cut through the bearing outer races seems to be the only option. Don't think I can get a Dremel in there but going to give it a red hot go.
    19,215
    Quote Originally Posted by link1896 View Post
    Each to their own, but...you know that stuff is dangerous to spray on your skin right? Your willy could frost bite quite easily and fall off! Maybe find a different aerosol lover.
