Thread: monarch plus m/m tune change to m/L3 tune
    Mar 2009
    272
    Default monarch plus m/m tune change to m/L3 tune
    Hey has any one performed a shock tune change on a rockshox monarch plus , from M/M to M/L3 ?
    As performed the task themselves?
    And what is an L3 tune ?
    Mar 2003
    2,349
    L3 is a lower compression shim stack than the L tune.
    You should be able to buy the replacement shim stack an install
    Have a look at the service and parts section of the rockshox site, its got a lot of good resources.
    https://www.sram.com/service/rockshox/49,152
    GK3
    Mar 2009
    272
    Default shock
    Awsome that's what I needed .
    Mar 2009
    272
    Default shock
    Any links pictures of actual L3 shim stack orientation ? By chance
