Results 1 to 10 of 18
Thread: MRP Ramp control
    Top Bloke DMan's Avatar
    QLD
    2,785
    Default MRP Ramp control
    Anyone running one? I'm presently running an RCT3 pike with 2 tokens and wondering if it's worth the $200 to get one? If this has been discussed can someone point me to the thread as the search engine gave me nada...
    QLD
    2,785
    Never mind the question, they're only for solo air forks....
    Mar 2003
    2,349
    How much do you use the DPA?
    GK3
    QLD
    2,785
    Quote Originally Posted by shmity View Post
    Never. I always leave at 160mm
    Mar 2003
    2,349
    Quote Originally Posted by DMan View Post
    Is it worth your trouble to swap to a SA? opens up a bunch more options for tuning the spring rate (mrp which is just on the fly token adjustment really, luftkappe, AWK etc)
    Otherwise theres a few coil conversions getting around these days for a similar amount of coin? The TF Tuned one will run in DPA or SA forks.
    GK3
    QLD
    2,785
    Could be. It's certainly food for thought.
    2,871
    Mate I hated my Pike DP partly because I was stuck with no upgrade option for the air spring. Coil was out of the question as it would be irreversible. Also I never used the lower travel setting.
    Ended up getting a DVO Diamond and am rapt it also fixed several other issues I was having with the Pike.
    Ask yourself do you want to pay for a Solo which really doesn't give you anything more but an air spring upgrade option.
    Mar 2003
    2,349
    Look I mean, if were talking about total fork upgrades, the mattoc is a worthy contender at almost half the price of the diamond as well.
    GK3
    QLD
    2,785
    It's certainly not worth changing it to a solo that's for sure. Just a shame there is so limited options for the DP like you say.
    QLD
    2,785
    I'm happy enough with it to not warrant a complete fork change and the coil spring is a no go for the reason that Tek said. I'll save my money for a bike upgrade in a couple of years instead....
