Results 1 to 10 of 17
Thread: Wheel building and Loctite?
    Senior Member ctguru's Avatar
    Belgrave South, VIC
    1,650
    Default Wheel building and Loctite?
    I've never used Loctite for wheel building
    Had a set built up a while ago and just snapped a spoke and it broke off inside the nipple, builder used RED Loctite, why RED fuck knows!
    I think the Loctite contributed to the failure
    Anyone else had any similar experiences?
    Member linkl8r's Avatar
    Apr 2015
    98
    Dan at Shifter Bikes recommends 222 AFAIK, which is purple. Red seems like it would be too strong for me.
    Sent from my Moto G Play using Tapatalk
    3,741
    Don't go back to that wheelbuilder except to ram the wheel up their arse.
    Use grease and adequate, balanced tension.
    Feb 2005
    221
    Default Maybe not as it seems
    Different brands use different colours; it may be a low- or medium-strength and something else was the cause
    I think the DT Swiss "Spoke Loctite" is red in colour
    Aug 2016
    Illawarra
    38
    I can understand loctite on a wheel that is expected to be ridden and unmaintained when it leaves the shop. If you actually maintain your bike there is no reason you would want any loctite there, just a dab of grease. You want the nipple to rotate on the threads freely after a few rides to adjust once the spokes and every once in a while after that. Nothing shits me more than rounding off a nipple on a perfectly good wheelset, especially when you have to replace your tubeless tape just to fix it.
    Senior Member redbruce's Avatar
    Aug 2009
    2,534
    Quote Originally Posted by The Duckmeister View Post
    This (I use light oil).
    Having said that Loctite would not cause failure described by OP, build quality will.
    Be kind, for everyone you meet is fighting a great battle - Philo
    Senior Member tkdbboy's Avatar
    201
    Is that for your recommendation above or wheel building?
    Belgrave South, VIC
    1,650
    That's what I thought
    I build my own wheels now
    3,741
    Haha, that advice is for wheelbuilding. When ramming wheels up people's arses use no lube for maximum discomfort.
    I've had spokes break on the workstand because the dumfuks at DT put glue in their nipples.
    1,568
    I'm not condoning Loctite in wheels, but how does it relate to the spoke breakage?
