Results 1 to 10 of 14
Thread: Coil in Pikes and rear coil shock in Spitfire
    Member Flip666's Avatar
    Jun 2016
    89
    Default Coil in Pikes and rear coil shock in Spitfire
    Got a set of pikes the other day for a hardtail build, and came across a coil changeover kit for pikes.
    Wondering if anyones had any experience with them, any good etc?
    Also have been wondering Wether to change to a coil shock on a Banshee Spitfire.. Anyone done it and does it work well with its suspension design?
    Currently running the ccdb air Cs
    Senior Member Ideate's Avatar
    Jan 2014
    2,178
    Quote Originally Posted by Flip666 View Post
    Ezkaton liked his coil I think. There's a few Spitfire PYR's running coils on here. Just do it.
    26,825
    About to test a coil on spitty. Just coz. Love the CCDBA on it.
    Senior Member the drizzle's Avatar
    Dec 2010
    803
    I run a coil on my rune and would never go back to air. It even tracks better on rough techy climbs. Perfectly suited to the suspension design imho
    Do it
    11,591
    Yep, CCDB Coil on a Rune too, heaps gooderer than the DBair. Spitty should be exactly the same, as long as you're not worried about the weight penalty.
    Sent from my HTC_M9u using Tapatalk
    Senior Member Ezkaton's Avatar
    Apr 2013
    Melbourne, VIC
    2,649
    Coil was great on the Spitty.
    Knocked the weight up a fair bit with the steel spring, but the improved small bump compliance and rear wheel tracking was so good.
    If I rode a fixie and nobody saw it, was it still cool?
    Jun 2016
    89
    Awesome, now what's good value? And do they need to be tuned internally to bike/rider weight or is the spring the only variable?
    4,195
    Spring is only for your preload/sag, much like your air shock air pressure.
    Damper works on the same principal as in an air shock. If you go down the route of a CC DB (even and iL) or DHX2 you will have HSC/LSC and HSR/LSR adjustments available. So unless you are a total sparrow fart or a complete fat bastard, you wont need a custom tune. You will need to set it up to your liking tho.
    FWIW, the CC Coil iL is a great coil choice for a trail bike being relatively light and small. Do youself a favour and fit the OPT bar remote for the climb switch..... Best...thing...ever! PS. but don't bother with the Valt spring in short travel. It weighs the same as the standard springs.
    Jun 2016
    89
    Thanks, I'm only 70kg's ringing wet.
    Was thinking the cc inline or db much difference between the 2?
    There is a inline for sale off a reign that could be of interest.
    Jun 2016
    89
    A mate has an enduro with the inline coil with bar mount Cs and absolutely loves it in all aspects.
