Results 1 to 10 of 16
Thread: 1 x 11 setup and question
    melbourne
    6
    Default 1 x 11 setup and question
    Hi all,
    I recently purchased a trek fuel EX9 with 1 x 11 setup, whilst the front chainring is 32 tooth and fine around my local trials, I'm heading to Bright/Fallscreek for a lads mtn bike weekend in a few weeks and are looking to purchase a 28 tooth ring for the hill climbs.
    Do I need a boost chainring or will any direct mount ring be ok?
    Andy
    4,289
    Quote Originally Posted by andy t View Post
    Hi all,
    Andy
    Hey Andy,
    Depends on a couple of things.
    1. Is the bike 148mm Rear spacing (Boost)
    2. Which cranks have you got? SRAM/Shimano/Raceface etc?
    Presuming you have a boost frame, there are different setups for Boost for different manufacturers of cranks.
    Shimano run boost specific cranks with a 94 BCD standard (6mm) offset chain ring.
    Raceface and Sram run standard cranks with a boost specific Direct mount (3mm) offset chain ring.
    This gets a little messier if you've got BB30 cranks (but I doubt the Trek has a BB30 bottom bracket)
    11,666
    Hi all,
    Andy
    The chainring will need to be the same as the existing one, even if DM, so GXP for GXP, BB30 for BB30, Boost for Boost, etc...otherwise your chainline will be fugged, and you will spend the weekend losing chains.
    Also, the smaller the ring, the more pedal feedback will be magnified, so check the suspension characteristics of your bike before committing. A 32t should be fine for Bright and Falls, I'm no climber, but the 32/10-42 works for me. Maybe look into getting a 46 on the cassette instead.
    Senior Member Keachy's Avatar
    Rye, Victoria, Australia
    156
    If you make the change 2 teeth either side of stock setup you won't have to change chain length. So a 30 or man up and punch out a 34 big dog
    2,906
    Best advice so far.
    Many people don't consider suspension kinematics that is affected by changing the chainring size.
    Oct 2008
    63
    Best advice so far.
    Any good suggested resources for this?
    Is a smaller ring necessarily worse? When will pedal feedback be most noticeable? Does the feedback vary depending on which sprocket you’re in at the back? Or are these sorts of questions largely dependent upon the specific design of the rear end of the bike?
    FWIW I have a very similar bike to the OP, a carbon Fuel EX 9.8 which has a 2x XT setup with 36/26 (vs a 1x SRAM on the aluminium 9). I’ve never been conscious of differences in pedal feedback from one chain ring to the other, but then I’m still trying to understand the basics of suspension setup, and haven’t been ‘looking’ for it – whatever it might be ;-)
    Oct 2008
    63
    (My decidedly non-expert take: I suspect the average rider is more likely to notice having insufficient gearing to get up a hill than they are to notice pedal feedback.)
    melbourne
    6
    Hey Andy,
    Hi TJmofo,
    Yes bike is 148mm rear boost
    Scram X1 cranks
    Reading the replies, maybe a should work my legs more and push the hills.... argh
    2,906
    Quote Originally Posted by puffmoike View Post
    http://www.ridingfeelsgood.com/suspe...edal-kickback/
    what is a yous indica's Avatar
    banned
    6,914
    Surely the 11 at the back has you covered?
