simplesimon76
anyone running the Widgit. i've had one now for about 1200km, not too bad, only problem is it needs a bash guard. but apart from that, it never misses a beat.
Why's that? The widgit system, to my ignorance, appears to provide the function of a bash guard in itself?anyone running the Widgit. i've had one now for about 1200km, not too bad, only problem is it needs a bash guard. but apart from that, it never misses a beat.
Weird I run the same setup and can put the guide all the way down to the chain, been a great setup for me!I experienced the same problem with my MRP X.1 when going down a rough bit of trail, I think the problem is that the chain guide doesn't sit low enough to the 32t sprocket, the instuctions said that you should allow only about 2mm between chain and ceiling of chain guide but with the 2 that I own I can only get around 4mm (using the stock 32t Xt chain rings) which means that when it get really rough the chain jumps off the sprocket then jams up the giude which then spins on your BB.
The only thing is to get a bigger size sprocket, I have bought myself a 33t and hopefully the adjustment will allow for a better set up.
Overall though I have to say a 1x9(1x10) is a pretty good set up.
The 'guide panels' (as I'm guessing they're called) on a widgit are super thin aluminium. As a result they're not much use as a bash guard, certainly not against any impact strong enough to do damage to your drivetrain.Why's that? The widgit system, to my ignorance, appears to provide the function of a bash guard in itself?
Yeah I have the 28t, works a treat.anyone running the Widgit. i've had one now for about 1200km, not too bad, only problem is it needs a bash guard. but apart from that, it never misses a beat.
I am. I'm using a Renthal chainring with XT 10 speed stuff, chain, cassette, derailleur, etc. It all works well.
Whether you need a chain guide upfront depends on the setup and the type of riding, I had an E13 but I ditched it and run with nothing and have had no problems - but then I am not riding any rough trails.Australia,
No spacers required to replace front and granny but ideally you should switch to a straight cut middle ring that isn't ramped or pinned.
You will need some form of chain guide up front, without question. I use a Rohloff, but MRP and e13 both make well respected ones too, as do DMR (although from memory theirs is pretty heavy)
How do you get a straight chain line without spacers, surely that would make the middle ring slide inwards, or does the chain guide take care of that?Australia,
I'm as smooth as a hack sawWhether you need a chain guide upfront depends on the setup and the type of riding, I had an E13 but I ditched it and run with nothing and have had no problems - but then I am not riding any rough trails.
thankgod I'll never have that problem (dont tell Zed I said that)In theory the middle ring would have as close to a central chainline as you'd get anyhow, it shouldn't need adjustment to work correctly as a single ring. Ultra precise chainline adjustment is really only required if you're setting up a singlespeed.
Old front derailleur clamps, reflector brackets, hose clamps are all good ways of setting up a front chainguide without an e-type plate. In fact, if you run a bashring as well, all you need is the 12g, $0 reflector bracket...Just custom make a new mount for an mrp guide, so instead of it being a bb mount, it attaches to where your direct mount FD would normally go.
If your not the handy type, give Gripsport a ring, I reakon he'd be able to fashon you something!
tomacropod just did that for my NRS-SS last week. While the chain tension from my Alfine tensioner was quite high, rough high-speed sections would occaisonally dump the chain. Does the trick - and now I'm just like Julian Absalon.Old front derailleur clamps, reflector brackets, hose clamps are all good ways of setting up a front chainguide without an e-type plate.
I've also run 1x9 without a chainguide on a HT and really can't recommend it. One day you'll lose the chain on a bump that looks too small to be an issue, and when it happens it could hurt a lot.Whether you need a chain guide upfront depends on the setup and the type of riding, I had an E13 but I ditched it and run with nothing and have had no problems - but then I am not riding any rough trails.
