Woffa
Rotorburn Enthusiast
34mm (black anodised) aluminium stanchions capable of supporting 203mm travel without difficulty
Magnesium casting lowers: parabolic arch for torsional stiffness, more vertical arch for asymmetrical stiffness, ovalised for deflection stiffness and lighter weight, seal head and arch closer together, lighter 'minimalist' dropouts, hollow crown on 1.5 forks, casting drops below axle for lower ride height, takes up to 2.8" tyres, improved turning circle
'No Tools Hex Axle' system - no tools (duh!) wheel removal (two small QR's release pinchbolts/handturn cinchbolts
'IS2 Integrated Handlebar Mount' - only on the triple clamp forks (duh!), two reaches available (45/65mm) using the same clamp, spacers supplied for adjusting bar height
'Intrinsic' speed sensitive SPV (see below) and cartridge 'TPC Plus' damping
All-metal adjustment knobs
Sub 6.4lb 203mm travel 1.5 single crown fork
Sub 7lb 203mm travel triple-clamp fork
4 models available:-
'Single 150' = single crown, 150mm travel, coil, 'TPC Plus' cartridge, 'Hex Thru'
'Single Intrinsic 180/203' = single crown, 180/203mm travel, coil, 'Intrinsic' cartridge, 'No Tools Hex Thru'
'Triple Intrinsic 180/203' = double crown, 180/203mm travel, coil, 'Intrinsic' cartridge, 'No Tools Hex Thru'
'Triple Ti Intrinsic 180/203' = double crown, 180/203mm travel, titanium coil, 'Intrinsic' cartridge, 'No Tools Hex Thru'
