S.
ex offender
Item: 2010/11 Boxxer coil spring leg, including stanchion, spring, topcap assembly, top-out assembly, and spring plunger rod - ie EVERYTHING from the left leg of the fork except the actual lowers themselves. Can be from a Race or a Team model, not too fussed about whether I get the dropstop thing or not.
Item Condition: Must be in good working order, specifically NO scratches on the stanchions whatsoever.
Price and price conditions: $100 max - can get it new for not much more than this so $100 if it's in primo condition, otherwise will trade my air spring leg for your coil spring leg + $50. Cheap upgrade to a Boxxer WC if you're currently running a Team!
Extra Info: Air leg is in good working order and has been serviced regularly. The spring plunger shaft has been shortened 6mm, as have the topout bumpers, in order to keep the spring piston lower in the stanchion (similar to what the 2011 fork does, but less extreme).
