ozzy osbourne
Check it,
Absolut SX
Initially designed for a slopestyle life, the Abso¬lut SX is going to show that its range of abilities will be much wider. Modern, compact, light, with a 140mm /5,5inches of travel, it will be as comfortable in a bike park as in a twisty downhill trail. Developed and build with Cédric GRACIA’s input, this bike is extremely reliable and knows how to boogy!
All the secrets of the Absolut SX
The Absolut SX uses numerous new technical solutions:
- Has a great size /stiffness /weight balance ratio.
- The main pivot point of the contact system is located on the bottom bracket, enabling a singlespeed build.
- Conical integrated headtube 1.5 - 1.1/8inches: ideal if you want a 160mm fork.
- New 10mm shock mount axles: Easier to remove and stronger
READ MORE HERE
Absolut SX
READ MORE HERE
