TBSM
The Bike Shed Mortdale
Hey Rotorburn'ers,
Ever feel like the suspension on your DH bike is a bit dated? Sick and tired of blowing cartridges, changing fork/shock seals and dampening adjustments that don't work??
Upgrade to Fox's proven 40 RC2 fork and DHX RC4 shock for $2449!
Saving of $819 off the rec. retail price!
In case you have been living under a rock for the last 6 years here's a little about the 40 and the DHX...
Want to kit your bike out with this awesome DH package from Fox before the summer DH series kicks off?
Head to; http://tbsm.com.au/
2011 40 RC2
For 2011, we've inverted the 40's FIT RC2 damper, and made it lighter in the process. This new damper lowers the fork's un- sprung weight, which allows it to react quicker, improving the 40's terrain following and front- end confidence. With its unique, single-wall bladder de- sign, the new FIT RC2 damper provides increased reliability, and consistently fade-free damping. Improved Bottom-Out Control produces a virtually bottomless feel enhancing rider confidence and front-end control. The new inverted damper design offers an ultra-wide range of adjustability, giving riders tuning options for every course. We've swapped the adjuster position too. By placing the new high-and low-speed compression dials on top, we're giving you easier access to fine-tuning your setup. Rebound is now on the bottom of the fork leg and the new knob provides greater clearance. The 40 receives the same Kashima Coat stanchions we tested on the World Cup circuit that reduces friction throughout the ultra-stiff chassis, which further improves its performance and reliability.
2011 RC4
The DHX RC4 is our flagship, purpose-built downhill shock specifically engineered to meet the demands of the athletes who make the world's most in-credible downhill courses look simple. The DHX RC4's externally adjustable high and low speed velocity sensitive damping, and our Boost Valve that provides position-sensitive ending stroke control, act independently from each other allowing the rider to dial in the optimal balance of traction, small bump compliance and big-hit absorption for the perfect amount of terrain following it takes to win championships. A large diameter shaft lowers internal pressures and increases oil flow throughout the entire shock allowing for the widest-possible range of tuning.
