Woffa
Rotorburn Enthusiast
Picked up my new ride the other week and took her out for a test spin on the weekend. All I can say is wow what a bike! She is weighing in at 16.9kg out of the box with an extra long frame.
Stock Spec:
FORK: RockShox Boxxer Team 650b,
STEM: Specialized P.Series MTB, direct mount, forged alloy, 4-bolt
HANDLEBARS: S-Works DH, carbon
FRONT BRAKE: SRAM Guide RS DH, metallic pads, Code caliper, 200mm rotor
REAR BRAKE: SRAM Guide RS DH, metallic pads, Code caliper, 200mm rotor
BRAKE LEVERS: SRAM Guide RS DH, alloy lever, reach adjust, w/ cartridge bearing lever pivot
REAR DERAILLEUR: SRAM X01 DH Type 2, 7-speed, short cage
SHIFT LEVERS: SRAM X0 1 DH, 7-speed
CASSETTE : SRAM X01 DH, 7-speed, 10-24
CHAIN: SRAM PC-1130, 11-speed, w/ PowerLink, nickel finish
CRANKSET: SRAM X0 DH, BB30, carbon arms, triple base, w/ Gamut bashguard
BOTTOM BRACKET : SRAM, BB30 to BSA 83mm adapter
PEDALS: Specialized Boomslang, 6061 alloy
RIMS: Roval 650b, alloy, 24mm inner width, 32h
FRONT HUB: Specialized Hi Lo disc
REAR HUB: Custom DT Swiss, Star Ratchet, XX1 driver body, 12mm thru-axle, 32h
SPOKES: DT Competition, stainless, 2.0mm
FRONT TIRE: Specialized Butcher DH, 60TPI, wire bead, 650bx2.5"
REAR TIRE: Specialized Slaughter DH, 60TPI, wire bead, 650bx2.3"
SADDLE: Phenom Expert, hollow Ti rails, 143mm
SEATPOST: Thomson, alloy, straight, 12-degree clamp
SEAT BINDER: Specialized 7050 alloy, single bolt, 36.9mm
Stock Spec:
