r.ayres1
Item: 2016 Ragley Bigwig Frame '29er' (small). Includes headset.
Location: S/E Qld (Caloundra area - could meet at Parklands on the weekend if needed)
Item Condition: Used (good) 'a few small paint chips here and there' - bugger all really.
Reason for selling: Trying something different
Price and price conditions: $175 + postage (around $50 to most East state cities) if you live in 'woop woop' please give me your post code and I will get a price for you (pack and send 'insured').
Extra Info: The regulars (and or observant) will know that I have recently bought a new frame (also steel btw) I just needed to make sure it wasn't a lemon.... It's cool �� .. The Bigwig descends a little better 'in the rough' and is a touch more compliant in the rear. The new frame climbs a little better (the frame angles and measurements would suggest so as well). As the mid 50s approach and the balls shrink the new steed suits just that little better. If you haven't tried a steel frame before (or for a while), for this little outlay it is worth the try. They really do keep you on the 'edge', and are more compliant than alloy hardtails.
* the last pic shows what 'Biggers' looked like when she was alive... *
2016 frame geometry 'below'......
Bigwig Frame Size Small (16") Rec. Rider Height (Imperial) 5' 3" - 5' 7" Rec. Rider Height (Metric) 160 - 170cm 170 Rec. Inside Leg (Imperial) 28" - 30" Rec. Inside Leg (Metric) 71 - 76cm Seattube Length (ST) 406mm Effective Top Tube (TTe) 585mm Reach (Re) 400mm Stack 645mm Chainstay Length (CS) 435mm Headtube Length (HT) 100mm m Headtube Angle (HTa) 65° Static (66.5° Sagged) Seattube Angle (STa) 72° Effective Seattube Angle 74° Bottom Bracket Drop (BBd) 70mm Wheelbase 1142mm Based On Axle To Crown 540mm.. 142 x 12 rear end... Headset for standard taper. Internal route dropper post compatible.
Any questions - just shoot me a pm.. Cheers
