Sold 2016 Specialized S-Works Stumpjumper FSR Medium (27.5+ / optional 29)
OZX
Item: 2016 Specialized S-Works Stumpjumper FSR 27.5+ 2016 (optional 29) - Size Medium
Item Condition: Excellent condition with minor scratch
Reason for selling: New baby (I mean bike) on the way
Price and price conditions: Sold
Extra Info:
This bike has been my fun bike for the last 18 mths.
It has proven to be the most suitable bike for the widest range of terrain.
Looks fantastic in what Specialized calls Gloss Carbon/Charcoal/Gallardo Orange.
Any questions or additional photos required please ask.
Specifications below photos
Pictures:
Specification:
DRIVETRAIN
CHAIN SRAM PC-XX1, 11-speed, w/ PowerLink
BOTTOM BRACKET SRAM PF30, OS press-in bearings
CRANKSET SRAM XX1, carbon, 148mm-specific chain line, X-Sync 28T direct mount ring
SHIFT LEVERS SRAM XX1, 11-speed, trigger
CASSETTE SRAM XX1, 11-speed, 10-42t
REAR DERAILLEUR SRAM XX1, 11-speed
WHEELS
FRONT HUB Roval Traverse, 15x110mm thru-axle, 24h
REAR HUB Roval Traverse SL, DT Swiss Star Ratchet, 54t engagement, SRAM XX1 XD driver body, 12x148mm thru-axle, 28h
INNER TUBES Standard, Presta valve
SPOKES DT Swiss Revolution
FRONT TYRE Specialized 6Fattie Purgatory Control, 60TPI, 2Bliss Ready, folding bead, 650bx3.0"
RIMS Roval Traverse SL 650b, carbon, disc, 30mm wide, 24/28h
REAR TYRE Specialized 6Fattie Ground Control, 60TPI, 2Bliss Ready, folding bead, 650bx3.0"
COCKPIT
SADDLE Body Geometry Phenom S-Works, Carbon rails, 143mm
SEATPOST Command Post IRcc, cruiser control technology, micro-adjust height adjustable, alien head design, bottom mount cable routing, remote adjust SRL lever, 30.9mm, S: 100mm travel, M/L/XL: 125mm
STEM Syntace F109, 6-degree rise, 31.8mm clamp
HANDLEBARS Specialized FACT carbon, 8-degree backsweep, 6-degree upsweep, 10mm rise, 750mm, 31.8mm
GRIPS Specialized Sip Grip, half-waffle, S/M: regular thickness, L/XL: XL thickness
SUSPENSION
FORK FOX 34 Plus Factory, 150mm travel, 3-position compression adjust, tapered steerer, 51mm offset, 15mm thru-axle
REAR SHOCK FOX FLOAT Factory DPS, AUTOSAG, Rx Trail Tune, Kashima coating, 197x47.6mm
BRAKES
FRONT BRAKE Shimano XTR Trail, hydraulic disc, Ice-Tech metallic pads w/ fins
BRAKE LEVERS Shimano XTR, carbon blade, I-spec compatible
REAR BRAKE Shimano XTR Trail, hydraulic disc, Ice-Tech metallic pads w/ fins
ACCESSORIES
PEDALS Resin Test Ride Pedals with toe clips, CEN std.
FRAMESET
HEADSET Hella Flush, 1-1/8" and 1-1/2" threadless, Campy style upper w/ 1-1/2" lower, cartridge bearings
SEAT BINDER Specialized, 7050 alloy, single bolt, 34.9mm
FRAME FACT 9m carbon, Trail 6Fattie Geometry, FACT IS carbon construction, M5 alloy rear triangle, SWAT Door integration, PF30 BB, fully enclosed internal cable routing, 148mm dropouts, sealed cartridge bearing pivots, replaceable derailleur hanger, 135mm travel
Hello
Do you still have the bike? If so is it possible to have a quick chat with you about it. You can either send your number or contact me at
[email protected] . I can either ring you or give you my number to ring.
Cheers
David
