Earlysport
Hi all,
I picked up this 2012 S works frame from a fellow rotorburner and put this build together for summer. I seriously like light bikes with little compromise ( my M6 DH bike is 33lb and has done two seasons at Thredbo, Val Di Sole etc with no breakage ) so after swapping all the bits from my AL Nomad and a few new parts this is what I've ended up with. I've got a pair of Gatestar 2.35 Racing Ralphs coming which might replace this new Michelin R2 combo - will try both and see as I havent ridden either tyre before. The RR's will weight about the same (550 grams each). I will also probably try a DB Air on this bike courtesy of a 2013 shock yoke - that'll add 200 grams so the bike will still sneak in under 25lbs. I am measuring up for an 8.75*2.5 stroke that will give me near 180mm rear travel too match the front. Might work might not we'll see.
Final weight is 11.11kg or 24.49lbs. Pretty good for a 180mm Float 36 forked genuine All mountain bike I think!
Frame - 2012 S Works Enduro
Rear shock - Fox Float Rp23 160mm travel
Front fork - Fox Float 180mm RC2 Fit. brake posts cut down to allow direct mount caliper with 180mm rotor.
Handlebars - Renthal Fatbar lite Carbon
Stem - Renthal Duo 50mm
Headset - FSA integrated. New machined lower sleeve to raise the fork 8mm inside the lower headtube to lower the front end and compensate for the 180mm fork.
Grips - Renthal Soft Slip on. ODI end caps
Saddle - Specialized Phenom carbon rail
Seatpost - Hylix (china carbon) cut down some.
Front brake - Magura MT8. Alligator 180mm rotor.
Rear brake - Magura MT8. Alligator 180mm rotor. Custom post mount brackets.
Cranks - Sram X0. Absolute Black narrow wide chainring 28T
Chainguide - none
Chain - KMC X10SL
Pedals - Dabomb barebones
Rear derailleur - XTR Clutch 10 speed
Rear shifter - XTR
Cassette - Sram XX 11-36
Front hub - Roval
Rear hub - Roval
Front rim - Roval Traverse SL Aluminium
Rear rim - Roval Traverse SL Aluminium
Tyres - Michelin Wild Gripper R2 advanced Front, Wild Racer R2 advanced rear.
Tubes - No Tubes
Other - Ti bolts. Over the BB cable routing. Removable rear axle lever. Inner tube chainstay guard instead of stock plastic thing.
Total weight - 11.11kg (24.49lb)
Earlysport
Chainguide - none
Chain - KMC X10SL
Rear shifter - XTR
Front hub - Roval
Rear hub - Roval
Tubes - No Tubes
Earlysport
