29/36 chainrings and 170mm crank
lincolnsydney
Am looking for a BB30 or GXP 170mm crankset with 29/36 rings. Or separately.
Normal Q factor though.
Preference would be for X0 or XX, but open to alternatives.
Cheers,
Lincoln
MrCove
South Shore Distribution
Cheers,
Lincoln
unusual combo, there will be a huge amount of duplication
XO/XX generally run 26/39 or 28/42 (i ran a 28/39 set up for a while)
i don't think the standard spiders on X0/XX will run less than 38t on the outer
there are after market options though, Home Brewed, Wolf Tooth, etc
104mm BCD cranks are probably your best bet for 29-36
but
your front mech won't work as its designed to if there is less than 10 teeth differance between ring sizes
maybe just give 1x10 or 1 x 9 a try?
casnell
but
I've got a 37 renthal in 120BCD, but that's the smallest that'll fit.
ido09s
I have some XX cranks i want to get rid of
GXP, pretty sure they are 170mm will check, 39/26, 56 Q factor
After $100 plus postage if your not in Sydney
