After some Stem advice
kiwiinmelb
Hi, After a bit of advice with stem set up if poss
If I was to go from a 70mm stem 0 degree rise to a 70mm stem with a 25 degree rise ,
How much closer does that bring the bars , is it just a marginal thing or is it so significant I should go the 80mm stem to keep the reach feel similar ?
Cheers
Bugger all.
Assuming you are not using a flat bar, the rotation of the bars in the stem will have a bigger impact on how far forward or back your hands are.
