just had my first ride on a nobby nic today....Grab a rock razor if using it as a rear tyre, I much prefer it to other tyres i have run as rears (ikon, ardent, racing ralph)
The ralph was a better climbing tyre, but the razor grips harder when the bike is turned over. I also expect the razor to last longer as well.
Or roots...or expect them to last long....very over-rated tyreJust don't take the Nic through any kind of mud... or you can kiss that grip goodbye.
Yes, especially wet roots... be prepared to slip right off them!Or roots...or expect them to last long....very over-rated tyre
Mmm, I'm trying to ride-out my current Nic until the new one drops... but I may run out of tread before then.I don't mind the nobby nic for general trail riding, but when pushed hard it gets dangerous, it breaks away without warning and doesn't hook in particularly well. Found that out at >60km/h on the delitite track.
Curious to see the new nobby nic as you are when it's released.
Try the Rock Razor anyway. I was astonished by how good it is... Well, braking is shite, but rolling is cracking and cornering is way better than a Nobby Nic or even a Hans Dampf. After a couple of rides with my front HD regularly losing grip before the rear Rock Razor, I started experimenting with other front tires. Currently settled on a Specialized Butcher which seems good. The HD will not be going back on.Mmm, I'm trying to ride-out my current Nic until the new one drops... but I may run out of tread before then.
Thankfully summer is coming, so I still have my eye on that Rock Razor if I need to change tyres in between.
Yeah, I find it hard to have confidence in my Dampf up front when it comes to loose over hard, it slips just like any other tyre I've tried when leaned over on flat ground. :/Try the Rock Razor anyway. I was astonished by how good it is... Well, braking is shite, but rolling is cracking and cornering is way better than a Nobby Nic or even a Hans Dampf. After a couple of rides with my front HD regularly losing grip before the rear Rock Razor, I started experimenting with other front tires. Currently settled on a Specialized Butcher which seems good. The HD will not be going back on.
I quite like the current nic, but I don't see a lot of the wet either.Curious to see the new nobby nic as you are when it's released.
It's probably a matter of taste. If you like to corner hard, lean your bike over and don't mind a bit more vagueness when upright, I reckon try something other than a HD. I swapped mine for a Purgatory I had spare for the rear. The HD felt better generally but when it came to maximum cornering grip, the Purg was clearly better. The Butcher is narrower than an HD, a shade lighter, rolls about the same but grips better. I'd also like to try the Maxxis DHR2 2.3. Both of those options are no bigger or beefier than an HD (probably a touch thinner, similar weight and cheaper...). I've become confused as to why HD's are so popular. Maybe I'm missing something.Yeah, I find it hard to have confidence in my Dampf up front when it comes to loose over hard, it slips just like any other tyre I've tried when leaned over on flat ground. :/
Shame because everything I read about it before putting it on praised it.
It felt great compared to the Nic up front, but still lacking.
I'd consider going bigger/better/beefier but I'm only on a Trance, so it's not that big a deal I guess.
Look forward to trying the Magic Mary on my DH build though... just gotta wait until late December for that.
I don't really get worked up over tyres but the old NN is crap for sure. There's absolutely no warning when you get near the limit with it leaned over in a turn. I hit the deck a few times and went down so fast I still had both hands and both feet on the pedals (on flat pedals no less). An awful front tyre if you like to tip the bike over to corner.I don't mind the nobby nic for general trail riding, but when pushed hard it gets dangerous, it breaks away without warning and doesn't hook in particularly well.
Yes, it's their only downside. I find the volume of a Conti Trail King/Rubber Queen larger than the Minions as well.Not completely sure but aren't Minions pretty heavy? .
I've just ordered a standard compound HR2 Exo to try on the front, the current Ardent will go on the back, replacing an Ikon that's close to worn out. From reports, should be a step up all round.Not completely sure but aren't Minions pretty heavy?
I'm going either 3C or Super Tacky HR2 on the front and Ardent on the back next purchase.
