ZTTO store on Ali...apparently...from memory.So you ordered from Garbaruk direct?
Chullora is where the big Aus Post interchange is in Sydney I think.
At least you have the eccentric which you can ride in all weather conditions if you are keen.No need for sad face @slowmick
Ive got bikes to ride and it’s something to look forward to.
How’s the Prevelo going??
Ahhh I know that trauma! All you want to do is buy all sorts of stuff (bikes) for your kid but you have to hold back lest they become spoilt turds. I usually stick to it but with bikes all bets are off.At least you have the eccentric which you can ride in all weather conditions if you are keen.
Prevelo is in the garage - will come out on the 16th as a 4.5 birthday present. As an only our daughter is pretty spoiled so we figured she'd get a new bike for some event/reason.
Yeah, was never in Garbaruk league. Worth trying for the brass.Garbaruk wins on weight handily then, it's only 295ish grams. Are all the bottom 10 gears CNC'ed steel on that?
Also, yes to the bottom 10 on the 9-46.Garbaruk wins on weight handily then, it's only 295ish grams. Are all the bottom 10 gears CNC'ed steel on that?
Thats pretty good at 262g, guessing it was a ZTTO SL ?Weights are in.
362. Who’s on the coke now?Thats pretty good at 262g, guessing it was a ZTTO SL ?
A possible option to replace the wrecking crews cassettes in the future, one is currently on a 12spd Sunrace XC and the other on a 12spd NX which is normal Shimano spline.
In my minds eye...but it’s dark outside...I reckon the cassette isn’t pulled on all the way. I didn’t want to over tighten a cassette of unknown quality. Another 1/2 turn would probably do it. Dare I?
I’m not Hampb.....oh, awkward. Works a treat with the 0.5 washer. It sits in the dropouts perfectly hidden and stays there when wheel is removed. Will report back on trying it in other frames.
Looks like it's made from brass, would explain a lot.Forgot to mention earlier, I can report that the 'Fovno' 60t ratchet aintnofarkengoodatall. Installed with a light coating of proper DT Special Grease, made it through 4 rides, started skipping/spinning on me up the climb to Shearpin at Derby last weekend. Was expecting it to fail so had the original 36t in the pack to swap in on the spot thankfully.
Curiously, it seems to have had most of the damage done on the outside of the teeth. Edit: Think I just figured out why that is - when meshed together the outside of the teeth fit nice and snug, but the inside has a noticeable gap & the teeth are barely touching. The mating surfaces seem to be angled slightly inwards
Thats no good, I have 120km on mine with no issues yet.I can report that the 'Fovno' 60t ratchet aintnofarkengoodatall.
