hifiandmtb
Sphincter beanie
It's the methadone clinic, isn't it?
Do you mean;It's the methadone clinic, isn't it?
There's one not too far from one of my jobs. There seems to be less in town though. 5 years ago I rode past 6 going to work each morning. Work was in the same area.It's the methadone clinic, isn't it?
D) where my Trid now hangs.Do you mean;
a) where @pink poodle works
b) where @pink poodle ’s customers work
c) porque no los dos?
Collect and reuse them for the same crowd when they return.So many take away cups to throw in the bin.
This is a good idea.Collect and reuse them for the same crowd when they return.
Normally the spacers are with the BB? They have always been for me.Got the headset in, got the dropper cable in and then got a bit stumped on bottom bracket fitting. Crank was off set in the frame, which turns out because there are spacers on each side of the bottom bracket needed that were missing from the crank order.
Sigh. At least they seem to be standard parts I should be able to get locally...
+1Normally the spacers are with the BB? They have always been for me.
No, not those spacers. Part number 6 https://dassets.shimano.com/content/dam/global/cg1SHICCycling/final/ev/ev/EV-FC-M6120-1-4757.pdfNormally the spacers are with the BB? They have always been for me.
Ah, the "boost" crankset spacers. They're a bit odd... But yes, required.No, not those spacers. Part number 6 https://dassets.shimano.com/content/dam/global/cg1SHICCycling/final/ev/ev/EV-FC-M6120-1-4757.pdf
Ahhh yeah - Funnily enough my PF to 24mm Threaded BB has a shit tonne of those spacers with it to get correct spacing on cranksNo, not those spacers. Part number 6 https://dassets.shimano.com/content/dam/global/cg1SHICCycling/final/ev/ev/EV-FC-M6120-1-4757.pdf
And very missing with the aliexpress seller saying they are not needed. Sigh. Oh well, its only money.... If I can get them.Ah, the "boost" crankset spacers. They're a bit odd... But yes, required.
Week?Ergh... that sucks! Really not your week is it?
The inside edge has a small lip seal on it IIRC... Mimics the one on the crank arm itself to seal to the BB.Does no6 need to be keyed like shown on drawing or can it just be a tube? Easy for someone to turn on a lathe
Could an O-Ring work?The inside edge has a small lip seal on it IIRC... Mimics the one on the crank arm itself to seal to the BB.
Unlikely, I think the lip is side of spacer adjacent the ID. Thinking about it, it might actually be a rigid lip to stop the face of the spacer rubbing on the BB. All I can actually remember is that the spacers had to be a certain way around, and there was a small lip (~0.5mm) somewhere, haha. @Haakon - if you haven't already bought something I can pull apart the crank and check tonight?Could an O-Ring work?
I've ordered the parts in from the Pushys shop in Fyshwick. Will set me back 20 or 30 bucks I think. I ordered 2 spacers and 4 o rings.Unlikely, I think the lip is side of spacer adjacent the ID. Thinking about it, it might actually be a rigid lip to stop the face of the spacer rubbing on the BB. All I can actually remember is that the spacers had to be a certain way around, and there was a small lip (~0.5mm) somewhere, haha. @Haakon - if you haven't already bought something I can pull apart the crank and check tonight?
Sorry, meant to say thanks for the tech support offer! Thankfully the bike shop guy knew what I was on about and the parts I needed.Unlikely, I think the lip is side of spacer adjacent the ID. Thinking about it, it might actually be a rigid lip to stop the face of the spacer rubbing on the BB. All I can actually remember is that the spacers had to be a certain way around, and there was a small lip (~0.5mm) somewhere, haha. @Haakon - if you haven't already bought something I can pull apart the crank and check tonight?
