toodles
Wheel size expert
After posting up some pics of my frame here, I've gotten a few PMs about details on the anodising.
There's plenty of anodising places about, and depending on their experience and knowledge they'll range from good to completely useless.
Stripping parts
Firstly, you need to get your frame down to bare metal. The finish is important, as it will affect the final result. The most gentle method of stripping a frame are either paint stripper, acid/stripper dipping and soda-blasting.
Bead blasting or walnut blasting gives a nice brushed/dimpled finish which I guess would look pretty damn cool.
Garnet (so called "sand" blasting) tends to be pretty damn abrasive, so if you go this option, get a reputable operator and make sure they don't thrash the threads or bearing surfaces.
If your part/frame is already anodised, you can strip it with a strong alkali (read the instructions or you wind up blind, blistered or worse yet - wrecking your frame). Some anodising shops can do this for you.
Anodising
There's enough info on the interwebby that you could probably do smaller parts at home. Otherwise, ring around until you find a anodising place that seems to know what they're doing.
The finish of the stripped frame is important to how the anodising will tun out. Matt frame = matt anodising. Bright polished frame = Bright polished anodising. Textured frame = textured anodising. Huffy frame = haha.
The frame needs to be able to be drained or plugged. The Sunday frame I had drained pretty easy through the front end but the back was trickier. Multi-pivot rear ends can be broken down into parts and you can drain them through the welding vent holes. One piece rear ends need to be either rotated (PITA) or drilled to allow easy draining or plugged.
If they don't drain the priming stuff out of the frame, it can make the colour run on the dye stage.
Also worth noting is that the aluminium series affects the final colour. 6000 series will look different to 7000 series.
Make sure you have no dissimilar metals left in your frame. No bearings, bolts, anything that isn't aluminium. The cathodic process will corrode/coat different metals so make sure you only do one metal.
Stripping parts
Anodising
