Another n00b Question (20mm thru axle)
bassmonkey
I was wondering, if you have a fork and wheelset with a standard non-20mm thru axle, is it possible to fit a 20mm thru axle/hub/whatever at a later date?
belly_up
and even if you hub does have such a system, you'd still be running a quick release anyway. Unless you're talking about getting a wheelset now to go with standard dropout forks, and upgrading to 20mm thru forks later, then it's not such a bad idea.
