stocktrials
Thanks to TBSM for all their mechanical/workshop modifications as always!
Rode this bike to 3rd place in Elite at the MTBA National champs this year
Atomz is the trials division of Sunn bicycles from France - you may remember Sunn from the 90's!
The bike as whole, feels stiff and light at the same time.. without feeling flexy/light like some other bikes I've tried out.
Recently switched to dual Magura HS33 (first pic is most recent), from a Magura Marta disc on the front. Now noisy but super powerful!
Also an assortment of alloy & titanium bolts throughout.
Frame - Atomz Quark 2
Front fork - Atomz Elitis, 4-bolt mounts
Handlebars - Try-All carbon
Stem - Atomz 130 x 25º
Headset - First, internal
Grips - BBB foam (cut down)
Saddle - carbon fibre (not shown)
Front brake - Magura HS33, bled with water/coolant mix, 4-finger lever, TNN Kenny Belaey pads, Atomz mounts
Rear brake - Magura HS33, bled with water/coolant mix, 4-finger lever, TNN LGM pads, TNN mounts
Cranks - Atomz Elitis 175mm, alloy crank bolts, Echo SL 18t front freewheel
Chainguide - Atomz tensioner, built in to frame
Chain - KMC Z610 HX
Pedals - Wellgo MG-1, titanium axle
Cassette - Atomz 15t splined sprocket
Front hub - Atomz Elitis disc
Rear hub - Atomz Elitis fixed
Front rim - Atomz Elitis singlewall, 39mm
Rear rim - Atomz Elitis singlewall, 47mm
Spokes - DT
Nipples - red alloy
Tyres - front: Maxxis Hi-Roller single ply 2.1" / rear: Continental Trial Queen 2.2" (prototype)
Tubes - standard
Total weight - 8.86 kg
Chain - KMC Z610 HX
Spokes - DT
Nipples - red alloy
Tubes - standard
