SummitFever
Had to do the suspension bearings on my Trance. The rocker and rear triangle are carbon fibre so the age old approach of cobbling together sockets and off cuts of bar-stock that fit wasn't going to cut it. All made from PE100 (a type of HDPE) which is very strong but soft enough that it won't damage/scratch the carbon. Couple of hours of programming/design, several minutes to machine up and then literally seconds to press out each bearing and put the new ones in.
I used my hydraulic press to remove the bearings but just a bench vise to put the bearings back in. Got me thinking that with a little redesign could probably use the bench vise for removing the bearings too (they are not in there particularly tight as the bearing seats are carbon fibre).
