ianganderton
I'm just looking at sourcing bearings for my bike and have a load of questions
Firstly for the rear suspension of my 2005 Specialized Enduro I have the following specs from the manual:
2 x 6902 2RS 28mm OD x 15mm ID x 7mm W (BB Pivot Bearing)
4 x 6800 2RS 19mm OD x 10mm ID x 5mm W (Dropout Pivot Bearing)
6 x 6802 2RS Full Complement*24mm OD x 15mm ID x 5mm W
-2 x Shock link @ frame pivot bearing *
-2 x link @ seat stay (outer) pivot bearing
-2 x seatstay @ link (inner) pivot bearing
I've just been into Applied Industrial Technologies (Former SKF Bearing Supplies) in Mascot and been quoted about $20 a bearing for SKF. For 12 bearings that's $240!!!!
For a "Enduro Bearing Set - Spec Enduro 2005-06 150mm" from https://www.diymtb.com.au/displayitems.asp?cid=100 it's quoting $84!!!!!
Hooper bearings across the road quoted me about 10 bucks a bearing but I don't know what brand or specs
Enduro and SKF bearings are both something I recognise as being well respected in the bike world. But I don't have any specifications to compare. 3x a price difference seems a lot
Because it's in a suspension linkage the bearings aren't ever going through a full rotation. What difference does this make to the specs required?
What does the Full Complement specification listed in the Specialized Manual mean?
Both the bearing suppliers dismissed it but I can't help but think that Specialized are pretty good at knowing what they are doing, there will be plenty of engineering expertise kicking around so would only specify something if it meant something. Unless it's a typo of course
I'm also after bearings for my hope hubs. The rear axle is not feeling good so I purchased these while I was in so I can sort them for the weekend.
$46 seems like a hell of a lot
The specs for the hubs are
Rear Hope Pro 2 Evo
Axle
2 x S61903 RS (19.79) (17 X 30 STAINLESS BEARING)
Freewheel
1 x S17287 RS (n/a) (17 X 28 STAINLESS BEARING)
2 x S6803 RS (19.41) (17 X 26 STAINLESS BEARING)
Front Hope Pro 2/Evo
2 x 6804 RS
The bearing suppliers both struggled with S17287
Stainless bearings are specified? The guy at SKF dismissed this. Again I wonder about this as hope have good engineers who wouldn't specify something unless it made sense
Any thoughts gratefully received
Rear Hope Pro 2 Evo
Axle
Freewheel
2 x 6804 RS
