This. X9 or XO 9sp shifter, zee 10sp mech, keep your current 9sp cassette. Much winning. Still running this on a couple of bikes.I would go X0 9sp. SO crisp. But Zee derailer and X0 9sp shifter is also very good, and get the benefit of a clutch. Read the 9sp clutched thread.
It's because you blow all your cash on canned coffee at $20 a pop and gourmet lunches in strange places....For a long time I've run a x0 shifter and a x9 mech. The shifter is super crisp and reliable and in a relatively safe location. The mech is kind of exposed and easily damaged...I've never been rich enough to consider an x0 mech disposable.
That '72 Cafe au lait was money well spent.It's because you blow all your cash on canned coffee at $20 a pop and gourmet lunches in strange places....
This!I would go X0 9sp. SO crisp.
Also, a pea under 15 mattresses feels aweful, princess :drama:I don't think there's a need for the clutches if you have everything setup correctly (both my DH bike and trailbike are dead silent, never drop chains, and neither have clutches). They interfere with and add stiction to suspension action. I do run full chain guides on both however, if you don't do that then you probably need the clutch - but the stiction addition to suspension action is unavoidable since that's how they work - by adding friction to the extension direction of the cage, which happens (incidentally) under every suspension compression also.
Yep, absolutely agreed, I used to have the X0 shifter, X9 mech for years. These days I am running 10spd X0 for both, but if cost is an issue, the X9 mech is great.For a long time I've run a x0 shifter and a x9 mech. The shifter is super crisp and reliable and in a relatively safe location. The mech is kind of exposed and easily damaged...I've never been rich enough to consider an x0 mech disposable.
Yep, 10spd X0 is not a patch on the 9spd X0,X9 shift quality.Glad it's not just me. Very underwhelmed by the feel of 10sp SRAM on the demo bike I loaned, compared to 9sp.
The XO 9sp shifter paired with the zee or xt clutched mech is ALMOST as crisp, albeit slightly heavier due to the clutch.
I've been on x0-x9 10 speed (entirely brand new drive except front ring) for a few weeks now and have found it pretty sweet. Was on x0-x9 9 speed for millions of years before and can't say I find there to be a crispness difference. But I do find that I'm barrel adjusting the shifter a little more often than the 9 speed days.Yep, 10spd X0 is not a patch on the 9spd X0,X9 shift quality.
Haha, I'll spot it for ya easy. I've got a month on you here old man, I win by default!Also, a pea under 15 mattresses feels aweful, princess :drama:
Ive heard this touted, and I call BS. If done in a blind test, I'll eat a bag of dicks if people can tell when riding. :hand:
Maybe too much, I just adjusted it so it felt like it did when I got it but I guess that's could be a fair way off. Not sure if a hardtail would be a bit harder on the clutch but if I do a bit of riding it goes for about three months between adjustments.Just you. I've got zee on 3 bikes. All been on there for years. No issues. Are you running ridiculous tension?
