True.do you have centre lock hubs?
avids dont run centre lock rotors, unless youre changing hubs you wont be able to use centre lock rotors.
Whats performance like when you run avid rotors on something like the XT?
I think the thread starter has a very valid point when considering which brakes work best in what conditions.I think you may be thinking about your brake selection a bit too hard mate. How much is humidity going to affect your brakes really, car brakes are far more complicated and probably more prone to humidity lessening the performance but they dont use different brakes on cars in different countries (i.e. vw golf in england and vw golf here). Also isn't the only way oil can perform worse is if air gets in the line? I can't see humidity causing that, more likely damp pads or even rotor moving slightly? If I was picky enough to let humidity affect my choice I'd lean more towards pad/rotor than oil when making my choice
Juicy's are notoriuous for leaking fluid, it doesnt matter what conditions your in, I assume codes and all other avid hydros have the same problem.I think the thread starter has a very valid point when considering which brakes work best in what conditions.
I have Juicy 7s and Codes on different bikes and in high humidity/high temperature days, the Code levers start to jam up and piss oil under the reservoir caps. The Juicys, well, they're not too far off, levers not affected, but they weep out the holes in the cap. As well as being a pain in the arse to keep on remedying it before a ride on such a day, it also drips and leaves ugly patches on frames/forks/parts.
I've used Hayes HFXs and El Caminos before this and never had this problem. While i have no complaints about how they perform, I think the Avids just weren't made for such conditions. I think i've had enough of spending 10 mins before a ride letting out oil and wiping away spilt Dot liquid. Gonna give the new Saints a go as soon as i get me hands on 'em.
Thats what I plan to do, thanks.Tupper,
I run the xtr metallic pads on 07 xt brakes,160 rotor on the back with 180 on the front,what a difference metallics with 180 rotor's make,the change in performance is stunning,never ever fades,and the control over the modulation is fantastic,they have a great feel once bedded in!
Read the whole first page..What exactly is the problem with your brakes that you perceive is due to humid conditions.....
constant bleeding problems, pads keep touching the rotor, pretty much all signs of a poor quality brake system, however the stopping power is still the same.
maybe the high temperatures of the climate + high humidity content doesn't go well.
Yep,Thats what I plan to do, thanks.
You probably run the center lock rotors?
If not, what rotors do you run?
