Thats right, there is no true way to clean a poo brown coloured bike JoshI also let my bike drip dry, due to the my colour you can see where cloth hs been
so many comments need to be made
A like button is needed for this post.so many comments need to be made
1. why doesnt rotorburn have a like button
2. wouldnt want to drop it
3. clearly hasnt done squats or else he'd know to keep his back straight
4. I wonder what that does to the bearings, seals etc
5. thats an odd way to catch a fish
6. I wonder if corral will start growing on it
Maybe so but replacing bearings once a year costs $30 for a whole frame if you know where to buy from. Id much rather just do that then pull apart and grease bearings every so often.Don't be a fool and think that so-called sealed bearings don't require cleaning etc.
Sounds sensible to me. Good for the wife, the kids and the environment...edit...You dont NEED high pressure, i use it because i then dont need to use a $20 a bottle commercial cleaner as well. ...edit...... Ive got other things id rather spend my time on then going over my bike with a toothbrush for 30 minutes to remove all muck.
Slow down your going to give yourself skin failure.Maybe so but replacing bearings once a year costs $30 for a whole frame if you know where to buy from. Id much rather just do that then pull apart and grease bearings every so often.
You dont NEED high pressure, i use it because i then dont need to use a $20 a bottle commercial cleaner as well. All these people saying muc off and scrubbing and sponges and such. I can come home from a ride get the high pressure out give it a blast for 2 minutes and walk away with a bike that looks brand new. None of my bikes have ever been worse for wear because of using high pressure. Ive got other things id rather spend my time on then going over my bike with a toothbrush for 30 minutes to remove all muck.
mmm.. yes we have used CT18 as per others recommendations from this forum but there are some who reckon it fades paint and i remain a bit concerned as to what happens if it gets into bearings. Seems to me that water (and what goes with it) eventually ends up in a lot of mtb bearings (pedal, BB, hub, headset etc).CT 18 all the way, even works if you let it all dry out and cake up then applyi t 3-4 days later. cheap as hell too from super cheap auto.
and ulnlike mucc off it wontr damage the paint work if you forget about it.
i have been using ct18 for years and never had my paint fade on my bikes or my trucks. you are right about the bearings, but then again, if you think your gonna get through a few years on one bike without replacing bearings and bb's etc then your a bit nieve (not you personally mate that wasnt a dig) shit needs replacing every now and then but i can say i have had no adverse effects from ct18 as opposed to using "bike specific" cleaners.mmm.. yes we have used CT18 as per others recommendations from this forum but there are some who reckon it fades paint and i remain a bit concerned as to what happens if it gets into bearings. Seems to me that water (and what goes with it) eventually ends up in a lot of mtb bearings (pedal, BB, hub, headset etc).
