teK--
RB brainstrust and nerds please!
Due to concerns with galling, I am planning to replace some stainless steel (316 grade) suspension pivot bolts with Grade 12.9 steel bolts.
After reading this site: Torque to Bolts article, it seems I may need to adjust the torque spec to suit the new bolts, to ensure enough clamping force?
To put it into context, the stainless bolts were rated at around 85,000psi tensile strength, and the steel ones are 180,000psi. The site suggests you ideally stretch any given bolt to 75% of their tensile strength to reach what they call clamp load.
Inputting the stainless steel bolt specs to the formula on that site, results a recommended tightening torque spec of 13.44Nm... Not too far off from the bike manufacturer's spec of 13Nm (for the stock stainless steel bolt).
If I input figures from the 12.9 grade steel bolts, the formula suggests a figure of 30Nm which seems awfully high and will presumably cause other issues with the swingarm assembly.
What if I just stick to the stock spec of 13Nm with the new steel bolts???
