William said:
Q. Do you know if the original Coda levers will work with the Shimano calipers?
Q. Whats your advice on Shimano brake choice, I have to watch the dollars, but I appreciate good engineering.
1. No they won't, sorry. If you are buying shimano brakes, you will need to run shimano callipers, hoses, levers, and genuine shimano mineral oil.
2. I have used and worked on pretty much every brake in the shimano lineup, and would highly reccomend the deore hydro's. They can be had very cheap, and with the right pads, will perform as well as any of the other brakes in the lineup. If you are open to using ebay, and want some good prices/links, shoot me a pm and i'll be happy to help.
As for finding 160mm rotors to suit the 4-bolt hubs, I have no idea, can't help you there. I think it'll be a difficult job at best, and you'll have to do a fair bit of hunting.
Your other option there is to get someone like Grip to make you a pair of custom adaptors to let you use them on the 170mm rotors. It's very much possible, and I think it would set you back roughly $120 for the pair from grip.
To correct beno's post a little, while full-sintered pads (such as ebc gold) will transfer more heat to the system than usual, and may cause problems with the closed system brake; organic pads won't have this effect - so a pad like the EBC red should be fine. So if you want to save yourself the hassle of new brakes just by a set of the red pads.
Just to clarify though (since you havent mentioned it..), are the brakes actually hydraulic, or mechanical? I'm quite sure Coda made both. If they are mechanical, then you can disregard ALL the comments made above on heat and fluid and locking up.
-Udi
