I had a similar problem when I bled my 7's a few weeks back, just loosen the caliper bolt so it can move around slightly.
Spin the wheel and then apply the brakes, repeat this a few times, then hold the brake on and tighten up the bolts. This should stop the rubbing.
If that doesn't work you may have to loosen them off again and spin the wheel, then just align the caliper by hand until you can see an even gap either side of the disk.
Note: a good light source will do wonders here, I use a 500W halogen lamp.
Also when the wheel is spinning you will hear the pads rubbing if it is not in the right spot, so use your hearing to help you adjust.
If the pads are too close together, you can gently pry them apart with a large flat head screwdriver. Don't be too rough otherwise you will damage the surface of the pads.
Hope that helps you out.
