My 6 year old daughter reckons to just get some sticky tape to hold it up.........Hi all,
I broke my Clavicle last week and have noticed in the last few days hat my shoulder has dropped just over an inch below the other. Is this pretty much normal or is this going in the wrong direction and tending towards surgery?
thanks
J
No it's not normal, if you are talking about a change since the fracture - go see a doctor- take your X-rays with you.Hi all,
thanks
J
Hi J. I had the same thing a couple years ago and I found this: the body is remarkably adaptable and good at healing itself and surgery itself introduces another complication, but it is a gamble I would take because you really have to wonder if having your frame that un-symmetrical is a good choice if you can avoid it. I got surgery on mine. I wish I had chosen a different surgeon (I feel my surgeon didn't take enough care - the joining of the bone was left a bit rough so that one of my muscles/tendons/whatever it is 'clicks' over the bump on the bone every time I extend my arm around far enough) and I really wish I had started using my arm again sooner after surgery. I played it real careful and kept my arm super still for 6 weeks while the bone healed because I was concerned the pin inserted may dislodge if I use my arm too energetically - in the end I had muscles joining to the scar tissue because it wasn't being moved around. So remember - there is a good middle ground between keeping it still so that the bone heals but moving it enough to aid recovery with blood flow and keep everything in the region loose. I can suggest some very well regarded surgeons around the north side of Sydney if you like, send me a PM.Hi all,
thanks
J
agree, 2nd opinion important, surgery based on 1 inch definate, make sure good physio after surgery, no matter what surgeon says. Has to be done otherwise your future will be worse off that whole upper quadrant, too late if you leave it too long. Go get the plate boy!Definitely go and see your orthopaedic surgeon again, or go and see another for a second opinion.
I went through this a few years ago and waited for 6 weeks with the same issues until I got a second opinion and opted for surgery. 2 weeks after having the plate put in I was back in the gym bench pressing light weights.
The first surgeon's I saw at a public hospital maintained it would heal fine and straighten out in the process, but after 6 weeks there was no improvement and I was still in a sling and a great deal of discomfort. As above, I'd take the surgery if there's any doubt that it will heal straight and in the correct position.
