tomac204airshift
hi i just got a Brooklyn Machine Race link i need new parts or 2 hand parts or looking for the new the spacers for the rear swing amy and new chains wheels for jackshift , first thing did was Try take a part frame for repaint . i got stuck with trying to get the pipe the holds the bearings to the swing y andam bearing , had use 20 ton press when i got to 3 ton it did not move the pipe what did move more like cracked was the spacer between frame and swing amy , before i use more ton"S can i ask how hight do you need to go to get them out and is there ? only one side you can press them out if so which side left or right ? and do you need to use heat on them to take them out ,
i found out this Was most rusty or bounded bearings WE Eever seen the end i need heat use oil's and 1,5 tons to press it not move no matter which i try to press it out Well stuck , after 2 hours it came out )
sad part the bearings turn out to good, before i start try to take them out , all for a paint job(
