Bushranger
I currently own this bike
http://www.merida.com.au/2012-bikes/mtb-hardtail-29/big-nine-lite/big-nine-lite-3000-d.htm
and want to buy this bike
http://www.merida-bikes.com/en_int/bikes/detail?id=31
With the intent on turning the full suspension into my XC racing bike (I'm not fast, just fun and like the longer races) and having the HT as my commuter. So want the best parts on the FS. Am thinking of swapping some parts of the HT to the FS. Can you techsperts let me know which ones are worth swapping and are compatible. I think the brakes definately.
Mentioned in order HT V's FS
FORK FOX F32Fit 29er RLC 100 taper 15 V's 32 Float 29 CTD O/C- Evolution 100 Taper
BRAKES Shimano XT-Fin 180, 160 V's Shimano M596 180/180 mm
DERA-F Shimano XT V's Shimano SLX high direct
DERA-R Shimano XT-10 V's Shimano Deore XT
H/BAR FSA Afterburner flat 670 V's Merida Pro OS Flat, 680 mm
STEM FSA SLK -6 V's Merida Pro K OS, -16°'
H/SET BC Comp Neck V's FSA No.55E
HUB-F Shimano XT-15 cen V's Shimano SLX cen / -12 cen
HUB-R Shimano XT-12 cen V's Shimano SLX cen / -12 cen
RIM XCD lite Big29 D V's Big Nine Pro D
SHIFTERS Shimano SL-M780 3 V's Shimano SLX -3 / -10
What I am thinking is this if the components will fit
Swap Forks and Wheels as I think the HT has 15mm QR so wheel will need to go with fork.
Swap shifters, deraileurs, brakes (may need to look at rear brake rotor as the HT has 160mm but FS 180mm. I should be able to just use the XT finned brakes on the FS and either buy a 180mm rotor for them or use the 180mm rotor if it's compatible...
Would it be easier/easy just to move all parts from the HT to the FS?
Thanks in advance.
Thanks in advance.
