Can i convert 20mm to 9mm qr axle
Just wondering if anyone knows whether you can convert a sun rim single track from a 20mm axle to a 9mm qr?
Also as an aside did sun rim change to sun ringle?
Cheers
Depends on the Hub (hope 2 hubs have adapters avaliable ) .
Check the hub to see what brand and Google it !!
Is my suggestion.
Sun and Ringle merged...
9mm QR are shorter in axle width and your hub should be designed for both QR and 20mm axles...
I think TBSM has daBomb that does both 9mm and 20mms
Looks like i cant, its an axiom and they don't do converters apparently.
New hub time i guess.
Might as well get a new wheel. Replacing the hub and (probably) the spokes on a used rim is a bit like grandma's axe - hardly worth the effort. Why don't you see if someone will swap you for a 9mm QR wheel?
