I was also wondering why there should be 'side loading', but that explanation makes sense. Does this side loading damage the shock in any way, or does it just help wear out / damage consumables much quicker - ie is the problem 'resolved' by a service, or is it causing more major damage that needs other components replaced?
And what do you think of the upgrade? Is the shock any better, or is there no noticeable difference apart from (hopefully) it doesn't break.
I'm on a 650b Enduro with the DBInline and have had the shock serviced / repaired once so far. It's no longer under warranty (bought secondhand) but I'd rather pay out once for something decent than have to get the existing shock repaired regularly.
I think "side loading" (non planar loading) is a fairly common problem on a lot of suspension designs, but it tends to be more of a problem on bikes with a yoke extension on the shock. As mentioned above, the extra length of the yoke is creating more of a leverage arm acting against the seal head & piston which combine to provide the bending resistance on the shock.
The inline only has a Ø8mm shaft which is supported by a tiny guide ring & a 6mm long DU bush in the seal head. The piston itself is only supported by a 3-4mm wide guide ring/wear band. In other words there's not much support against bending when the shock is fully extended.
The first thing to wear on these shocks is the DU bush & tiny guide ring. It'll allow enough movement in the shaft to wiggle & weep oil. If it is left too long & too much play develops, the seal head starts exerting a lot more force on the inside of the inner tube.
The pic is of a Inline that came off a Enduro 29er (they seem to be the worse of the lot for some reason). Probably the worst case scenario where the seal head has flogged out & the piston guide ring has worn through the anodizing of the inner shaft & is wearing the aluminium away. The aluminium was embedded into the guide ring & the oil was blackened with very fine aluminium shavings. Most of the wear has occurred where the shock was at full extension.
Moral of the story - keep your eyes on the wiper seal where the outer tube meets the air can. Once that weeps oil, it's time for a service.
