You guys have waited long enough. It's a 2013 Cannondale Trigger 29er. As cool as the lefty supermax is, I opted for the Trigger 2 as I already had an XTR/Sram S2200 drivetrain and brakes as well as a bunch of other parts lying around from previous bikes (Truvativ bars, Fizik seat, pedals etc). I Picked up the wheels and forks cheap on runout so that kept the cost of the build down too.
I had the tapered steerer swapped out for a 1.5" straight steerer to keep stiffness to a maximum. I also opted for a 20mm through axle up front too. These things compliment the frame really nicely. The frame has through axles that link all the pivots together, as well as double stacked bearings for extra stiffness. Makes for an unbelievable ride that goes exactly where you point it. It weighs in at just over 13kg's with pedals, tubes, 2.35" tyres and an uncut steerer.
I took it for its first ride today (and my first XC ride in a couple of months), and initial impressions are very positive. I got a couple of personal bests and top 10 times on some segments (on the descents) at the local XC trails, all whilst being...err ... not so fit, to put it nicely.
The forks are exceptional. So much more lively and responsive when compared to the Fox Float/Talas kashima forks I've been running for the passed few years. In fairness though, I haven't ridden a CTD fox fork, and I really did take advantage of the 3 position lockout of the revelations today.
The brakes were also excellent with consistent power, feel and modulation for the ride, which featured some pretty steep brake burning descents. In the passed I've used Formula R1's, which were excellent light and powerful brakes, however the assurance of the 4 piston calliper meant I was always well within the brakes capabilities and could brake later and less into corners. I also like the avid lever design alot, just feels right to me.
The pull shock is great too, letting me get away with the extra travel of the bike without suffering on the flat and uphill sections. Most of the time I use the short and progressive 90mm setting, and let it go to 130mm for rougher descents and trails. It's great being able to have two different rebound speeds too. Setting it up a bit faster on the short travel mode and much slower in long travel. Once set up properly, I have't encountered a single issue with the shocks, I've been using one on my previous bike, a jekyll, since January. Also, CSG have tons of spares should you need them, and they're only a couple of days away from your lbs too.
In general, the handling was pretty good, certainly not as manouverable as the jekyll, but I was still able to negotiate the tight and twisty climbs. Was also absolutely fine in the air and on the way down.
Here's a crappy phone pic, I think you guys have waited long enough for this.
Full Specs
Frame: 2013 Cannondale trigger 29er - 130mm/80mm Rear suspension
Fork: Rock shox revelation 29er - RCT3 - Dual position air - 20mm/1.5" Steerer
Shock: Fox Dyad RT2, independant short/long travel rebound adjustment and two different compression tunes
Rims: Stans ZTR crest
Hubs: Hope pro 2 Evo
Brakes: Avid X0 World cup levers to Code calipers
Rotors: Magura storm 180/160
Shifters: Shimano XTR 2 x 10
Rear Deraileur: Shimano XTR Clutch
Front Deraileur: Sram X7 direct mount
Cranks: Sram S2210 carbon, 38/26 tooth
Chain: KMC X10
Cassette: Sram Pg1070
Tyres: Shwalbe Hans Damppf 29x2.35 trailstar compound
Pedals: Shimano M520
Handlebars: Truvativ Noir carbon
Stem: Cannondale C2 50mm
Seatpost: Cannondale C2
Seat: Fizik Gobi XM
Big thanks to Adrian at CSG, Andrew at gripsport, Monza imports for the forks/brake parts and of course my boss Andrew for helping to get this together.
Judging by the parts you're selling... it's a Cannondale Trigger 29er 2. Do I win the prize?
Cheers
Muz
Excellent detective work. 10 internet points to you :first:
