With motorbike carbon rotors, yes, with these, no I have no experience. hmmm. The organics (I mean the shitty resin based basically glued together bicycle onesaren't sintered made the same way? Organics have more power even with stainless rotors. Up to a temp.) usually can't handle the heat Maybe the carbon rotors cool quicker. Either way, rotor temps in Oz are rarely and issue., which is the whole point of using a composite rotor anywayThis is where you're mistaken. There are several other possible benefits too. Any of wich might be why us guys are trying them. , otherwise it's just an expensive wank. Fade resistance at extreme temperature is the whole point of itNobody has mentioned how they perform at temp, your speculating based on something(Moto rotors)that are only related by a material. . I suppose the tiny It's far from tiny. Sub 50 grams an end sure, but rotating weight, and hard to loose 50 grams off wheels if you've done tubeless etc without risking puncture or durability. weight saving on these things is worth it for some people...Weight savings is worth it for me. Durability is too if it's true, longevity is also if true, same with quicker heating and cooling.
