i was thinking close line pegs but i dont think it will take the beating..I'm gonna take a stab in the dark and say pegs...
mmmmm silverstar.....They use it at Silverstar in a braking section and it works fine. Just depends how you implement it really
but do pussys ride your track? if so, it will annoy you more than the "pussys". personally, i get a bit pissed off when people put braking bumps on my tracks, so i put in seperate lines, etc so they dont have to brake hard on the main, harder lines.the areas on the track are areas that you don't break on unless your a pussy. it should be right because it is just for landings
yer that step down is massive its like the size of a gutteryep spot on. were do you think i should put it? i was thinking on the 1st step down and and on some that new line were building.
depnds if you want to roll or jump of it. and you havnt been to the trackyer that step down is massive its like the size of a gutter
its out the front of your house on the roaddepnds if you want to roll or jump of it. and you havnt been to the track
na its on the princess highwayits out the front of your house on the road
just after the small drop only noticed cause i stacked near there beforeyeah its there but it is also on the shutes on the B-line..
Carpet sounds like a good idea.
