AngoXC
Evening lads and lasses,
Just wanted to get some thoughts on an issue that has come to my attention.
Last week, I purchased myself a set of Shimano MT65 wheels for my commuter. I could only get my hands on the Centerlock hubs so I also purchased a pair of centerlock adapters to go with the wheels (for use with my badass 'sawblade-style' rotors which are 6-bolt). All went together fairly easily last Tuesday and I've been making the commute to work ever since (which is made all the better with new parts!)
Today, I found that if I apply my brake, even though the rotor is held firm, the tyre/wheel can rotate a few degrees. (At first it felt like play in the headset until I saw that my wheel was actually moving). This is also evident on the rear wheel.
This evening, I pulled everything apart and found that the adapter can move a little on the splines of the centerlock hub (this is just sitting on the splines with no lockring or anything).
In addition to this, the pins that the rotor would usually sit in appear slightly smaller than the holes in the rotor. Frankly, it's a little concerning as I installed new brake pads and have been making hard stops at every possible chance so that they bed in quicker. If the rotor were to 'jump' the pins on the adapter altogether, I'd be in all sorts of strife!
Given that the adapters only cost ~$12, I figured I'd wear their cost and just get some proper centerlock rotors but what concerns me is that the play in the adapters has damaged the spines on the hub.
Just to check, I've test fitted a pair of Saint/XT centerlock rotors (fitted to my other bike) to the MT65 wheels. Without the lock ring, they do move ever so slightly on the centerlock splines (where as on my XT wheels, the rotors sit firm) but when the lockring is fitted and the wheel is in place, there doesn't seem to be any movement that I can feel.
My question is, should I trust my potentially compromised wheels? There has been a fair amount of force applied over the past week with ~250km of commuting plus some hard stops so I wouldn't be surprised if the splines on the hub have worn ever so slightly but with a 'proper' Centerlock rotor fitted, could I expect to encounter some difficulties in the future?
I'd like to avoid the pain-in-the-bum that would be contacting/returning these wheels to the place of purchase but part of me would really like the play it safe.
Any thoughts would be much appreciated.
